asus rampage 4 extreme backplate
trazomfr
hello,
to set up my H100 I remove the backplate of origin. She seems stuck and I can not force.
Do you have a tip to remove it? thank you.
H100 fits on the original back plate fella.
Mine did not fit it. I use the backplate of X to get there. It is designed for the Intel processors based on the notice.
Anyway the chance was not on my side, the H100 was defective.
The pump was not working, the control system fan either.
Bad luck does not stop it either,the black ram slots not working.
So I tried the red slots but only 3 of 4 slots working. I only had 12Go available on 16.
I'm going to RMA the H100 and R4E...
