I was searching BF3 DirectX crash and there is countless information about this with many different cards. There is no one solution. It looks this is broken BF or something else.As a few others above have said it's probably a BF3 issue, Google it so that you don't waste your time re-installing windows.
i had to take the gpu memory from 1250 to 1200 to create a stable pc, i find that the factory overclock has issues.
If fresh install doesn't help i will change this card to another maybe GTX 780.
Also in Crysis 3 88 C is high. Backplate is very very hot that i can't even touch it. My case is open for now.
I remember reading that, poor guyI'd also not recommend touching the card when it is on, someone fried a 780ti on here recently by doing that.
Thank's guys for help. I have installed newest drivers. And i updated directx. And there is no more any error for now. But im not happy with temps. On BF3 88C byt Crysis 92C. Also i have shadow artifacts in metro Last Light and it doesn't work well. I have ten days to swap this card to another one. I can change it to another R9 maybe TRI-X or VAPOR-X or i was wondering about Palit GTX 780 Super JetStream. What do you think guys?
