Scoob
Hi all,
I have an ASUS P8Z68-V Pro motherboard, a fairly main-stream board I think. However, after some searching as well as speaking to a couple of water cooling parts suppliers, I cannot find a water block for this board.
I know Chipset / VRM blocks for higher-end boards are available, but not for mine. Am I missing a trick here? I mean, are the higher-end boards in the ASUS range similar enough for blocks to be interchangeable? I'd not expect that to be the case. Is there anyway to adapt another block to fit my board that anyone has discovered?
The thing is, my CPU runs lovely and cool, both my GTX 570's run lovely and cool, the whole system is wonderfully quiet too! However, my chipset . VRM heatsinks - the ones around the CPU - get really rather hot to the touch. I know these are supposedly rated to 105c due the the "superior materials" or whatever the blurb is today, but keeping these bits nice and cool too has got to help with stability as the VRM's etc. get pushed harder when overclocking, hasn't it? I could turn my case fans up to 12v (they are currently on 5v) yet that would create a huge amount of noise relative to my near-silence currently.
Anyway, I'm sure lots of people here have the ASUS P8Z68-V Pro board, or the near-identical (to the eye) P68 boards - has anyone found a Chipset / VRM block that works with these boards? Ideally UK sourced as that's where I am.
Any responses appreciated.
Scoob.
Scoob.
