I have been getting BSOD on first boot for quite a while now using a year old BIOS (0401). I've got my E6600 stable on air at 3.5ghz no problem at all.
I decided now would be the time to try and update the BIOS so I downloaded the two latest versions 0703 & 0801.. The latest is only a couple of months old. Anyway I could install either from the BIOS utility as it kept coming up with 'Downgraded ROM file was not suitable for the system'... Ahh perfect.. As if I know what that means.
I decided to risk it and flash from inside windows which actually worked.. Thought I'd broken it at first though as I had to reset the CMOS before it would boot. I couldn't get it to boot into windows at all with the settings that were still saved in there. It turns out that both BIOS's were useless OCers.. It would barely boot into windows at 3.1ghz.. Wouldn't make it at 3.2ghz. Mmmm what a great update there ASUS!!
Why bother wasting time making a BIOS worse? Ok yeah it probably fixes other problems but not mine so I don't care (selfish
At least this time the BIOS flashing utility worked and I could flash back to 0401 and first time it boots straight in nice and stable at 3.5ghz..
We'll see tomorrow whether it still BSODs on first boot.
