Asus Motherboard Bios Updates ?
Filby83
Hello,
I have the I-Deluxe ITX.
There has been updates for my board, most of the ones that are newer than what i have installed say: "Improve stability" but the newest two updates both address different problems, ones a boot to Windows PE fix and another is to improve Ram compatability.
However im stuck as to weather i need to just install the newest one? would the newest update include all the fixes from the past updates or are the ones for specific errors just that ?
Or do i need to install the last system stability fix update and leave the PE and RAM fix updates ?
if you're not having an issue specifically addressed by the latest bios, don't update.
If it aint broke don't fix it ;)
