Asus DirectCU 768 GTX460
TMaksimov
Okay I currently have my cards set-up in afterburner at these settings:
Volts - 1.087
Core- 850
Shader- 1700
Memory- 2100
Question is can and should I push them harder?
yeah mate those cards will do 900 core easily mate, but u might need to drop the mem to 2000 tho all 3 of my reference 768's do 900 on 1.087 my reference asus one does 930 core on its own
I get unstable machine on my first card when I clock it to 900 at 1.087. Higher voltage?
As long as the temps are in order aka fine to deal with ,. you can go and push more voltage !
but i noticed that 900Mhz core is most of the time the hot spot on these cards ...
yeah in sli they wont reach the same clocks as in single i can get 930 on max on my asus reference my inno3d's do 915 max
you gonna flash ur card to get more volts?
my 1gb cards i have set as stock volts at 870 or 880/1760/2100 with 50% fan keeps them cool most ive pushed them to is 930/1860/2105 at 1.07v
i did 880/1760/2100 at 1.062mv using a 1gb versionand a single card
u dont need 1.087 for 850 but aim for 2100 mem there was something like a 200-300 PPD diff from 880 to 900
