Ashton187
I'm not trolling, I'm just saying getting a VERY good sound card and crap headphones isn't the way to go. Steer clear of gaming headphones.
So PEXON, would a pair of Sennheiser Pc 360 G4ME be a good match for the sound card?
I'm sorry but I'm an enthusiast and I want the most I can get out of the best product I can get not buy the lower part and oc it to get to the higher part. I want to go beyond the higher part. its starting to chap my arse abit all of y'all taking it so far as to take 3 pages to convience someone to buy what YOU think is better, when its clear and said several times that the poster wanted the 680 and 4GB of mem.
Everything else looks alright, except the sound card, the headset uses USB. Unless you already own a 7.1 system already, but then i wonder why you need a new soundcard.
Apparently for there price Audio Technica ATH-M50 are meant to be pretty awesome.
If you like your ears being clamed. Beyerdynamic DT series, ATH700 range, Denon 1000/2000 or Sony MDR-V6
VERY VERY good bro!
VERY VERY good bro!
VERY VERY good bro!
990 are semi open back and the DT770, I have them too, are closed back and leak very little sound and let very little in, even though they don't have ANC.
I'd suggest the DT770 PRO 80 ohm and a Xonar STX
I suggest the 80 ohm for the sound card or 250 if you are using an amp. The 250's wont sound as good through a straight soundcard and no amp.
