name='Phil Stanbridge' said:Okay that does suggest it is a controller board issue - its not quite as drastic. You may be able to remedy this yourself. What I advise is unpacking the unit, leave in disconnected as such from your cpu but attach the USB to a working pc. Fire the unit up via the mains. Install the software on the working pc and flash the firmware. It sounds like the bios is stuffed. This will fix most of the initial problems. If it doesnt work then I need to take a look at it.
THANKK YOUUUU!!
