Arggh dont know what to buy
Ghosthud1
Hello people just wanting to ask weather to buy the p5q-e or the Asus Maximus II Formula, if i buy the maximus i wont have enough money for the q9450 but if i got the p5q-e then i will be able to afford and also if i did buy the maximus what cpu could i get instead of the q9450
I'd get the P5Q-E, mainly because it is a P45 chipset and it is a good motherboard. If you want to save some more money.. go for the P5Q Pro instead, it is nearly just as good ;)
the heatsinks dont luck as good, and i know it doesnt matter but i luv copper lolz i still cant decide and isnt the maximus 16 phase power design
P5Q Pro. If you spend ALL your time looking inside your computer rather than at the computer screen, get the Maximus :nono:.
hope it lives upto its name and all R.O.G ftw, but i just found out i can afford a q9550 so i think im sorted
yeah the only board what had the same colours as my mod theme lolz, and im putting a 4870x2 inside later so no crossfire
sorry about not replying ive been away for weekend racing :)
and im just assembling the parts now, also the memory im using is the OCZ 4GB (2x2GB) PC2-8500C5 1066MHz Reapers
