Anyone know where you can buy just the little White rubber thingies for Fans
name='Dav0s' said:
you dnt use screws?
lol, it sounds like hes using what are termed "rubber grommets" which are crap compared to metal screws, but are meant to dampen the fans noise a bit.
Well they're certainly crap enough to break whenever touched but they do do the noise dampening bit well.
also wouldnt they get rid of some of the vibration
They do a bit, but you can get various types of dampers, such as this one by Vantec, which goes between the fan and the case
The best ones I have used, are these by Acoustifan, which go in the screwholes on the case,
although in the end, I find it easier and cheaper just to get quiet fans ;)
definately, they don't make a great deal of difference with loud fans and much less dofference with quiet ones. Near the bottom of things to try for a quiet pc. You can go the DIY approach and buy some foam earplugs - cut them in half and they do a similar job.
