Anyone know where to buy a gsync module
Excalabur50
Well-known member
As the title says anyone know where to buy a gsync module as mine is stuffed I want to get a replacement and fix it myself but Google is hopeless it keeps directing me to monitor sellers
Thanks Peeps
Have you opened the monitor to make sure there is an actual Gsync module in it, dude?
I don't know if Asus etc buy them like that or whether they are not the separate board of old. They may be incorporated into the PCB. I would check first, they don't sound cheap !
It's the PG278Q it's got a G-sync module in it and all the documentation I've been able to find shows it as a daughter board held in by two screws so hopefully I should be right
