Anybody know how to remove these...?
I absolutely have no idea whether this is in the right section or not but i guess its the most appropriate.
Anyway, for some reason, from today when i right click on folders, there the box that comes up seems to be really massive!
Its from 'Add VLC media...' to 'Play in Winamp'
It wasnt like that yesterday.
Does anybody know how to remove/edit? Im pretty sure there's a way cause it wasnt like that yesterday.
Thanks
*Slight changes like these annoys me :(
You can deactivate those in the programms. If not you can uninstall the programm and reinstall with the boxes that say something like "add context menus in explorer" unticked.
You can try to remove them manually by fiddling around in your system. But I don't do that anymore. In the long haul often something gets screwed and you have to reinstall Windows.
