Any advice for MB and CPU
Zanc
Ahoy fellas!
So I am in need of new motherboard and processor since my current ones are a bit outdated. My current motherboard is Asus M2N68-LA (Narra3) and cpu AMD Athlon 64 X2 5000+ @ 2.6GHz. My budget is 250-300€, not going to OC it. Iyou need any more information, just ask and I'll try to answer ASAP.
Cheers!
you will need more ram too :/
any retailer that you will be using? only if we know where your buying from its easier to work with your budget
Im guessing Finland as thats his chosen location under his name. If hes not OCing and is on a tight budget then he could buy a bundle like this CLICK ME good CPU and the mobo/ram isnt too bad. Comes in at €302.19 including VAT and delivery{to Ireland i dont know how much more for Finland} a little over 300 . . . .but 3 euro isnt hard to find
I dont know if that site delivers outside UK/IRL, although their english one might, dabs.com i think.
Since Aria is partners{?} with OC3D might be better to check their site, i dont use them so i dont know what they have bundle wise.
I haven't thought about using any particular retailer, theres one retailer in my city, if u have any ideas for mobo/cpu I can always check if they have that.
Got 3072 MB RAM btw
