Antec H20 920 cooler fitting question
jimbojames
Hi All,
Question is, will an Antec H20 920 fit in to a Corsair Obsidian 650D with an Asus R4E with 8 sticks of Dominator RAM?
Thanks in advance,
James
ummm... why wouldn't a water cooler fit :'{ confused... ofc it would and if it didn't fit in the back your mount it at the top..
I think the 650D has only 80mm clearance in the top. The H2O 920 is a 50mm rad and two 25mm fans, I dont think it would fit in the top. Should be no problem if you install in on the back exhaust.
