Hi Friends !
Just got my Antec 900 and installed my System with the Stock Fans (4 Fans). I have a Cooler Master 650W Power Supply.
I want to install an extra 120mm Fan on the Case's extra fan provision i.e on the case Window. My problem is that I have run out of Power Connectors (or plugs - dont know what they are called
) and I cant give the extra fan the power to run.
Just wanted to request you to kindly advice and guide me if there's a way that I can connect an extra Plug to connect the Extra fan ? Is there any way to do it ? Is there any splitting adapter like thing available to do this ?
Please help me on this as I desperately need to install the fan (because I've got an extra fan
) and now I cant use it....
Please help me friends
Thanks and Regards
Kush
Thanks and Regards
Kush
