Another Noctua question?
KING_OF_SAND
i have been asking allot of Noctua questions, and that is because this forum is totally awesome when it comes to the Noctua. my question is which fans should replace my Noctua fans? i want to stick some fans that a little faster and just as quiet. i had in mind a corsair 120mm 1700rpm fan that went to my H50 which is dead silent, but i cant really find a nicer fan to replace the 140mm in the middle. does anyone have any suggestions? i am looking for something black, and or that glows white.
Quick answer is they dont exhist. The Corsair ones are noisey as F*** aswell.
also.... you dont need them mate, it works. Its an industry leader it doesnt need touching, you will just ruin it.
The fans are the heatsink are tuned to work together dude
i also want to replace them because the colors a FUGLY. i like black or white to match my color design in my case. and my corsair fan i cant here at all, in fact i use it as a fan to cool me off and i dont even notice its on most of the time. maybe ill get some latex paint and paint them.
Paint would be a better idea, just use plastic primer and normal car paints. You will have to take them apart though fella. I quite like the colours now tbh.
yer i have gotten to like the noctua colours,but i have had loads so just like evrything you get uste to them
thats the thing. i can get used to them if they were in a different case. i am trying to make a computer look like a show computer. i have invested hundreds of dolors in modding my case to were i do not want to see ugly tan and brown.
yea i was looking at that 140mm enermax but the problem with that is its only 700rpms and that is WAY to slow. the noctua 140mm is 1200rpm.
then have a look ate the enermax appolish vegas,they can go to 1500rpm at 12v and have white LED's i am shure there is a black one there jst expensive tho
or thet slipstream i linked
