AMD steambox help needed
MSI make terrible AMD mobo's...
Hmm thats what i get for buying a 36 euro mobo then i think :mellow:
Good thing i had no intention of OC-ing it but rather undervolt it to keep it cool and silent, also keep in mind the fact it's aircooled.
I will give AMD's own prog a try tomorrow then to see how big the difference is witheven the bios readings,
which i expected to be acurate lol
In the end i think a "run it as it is" approach will work best. ^_^
I told you :P
Yes you did indeed but i didn't listen and had to go for the in stock, dark looking mobo that i liked, and was cheap as hell to.
But then again, it runs fine as it is now, and in it's current state is how it will stay pretty much (no OC-ing).
So as far as the bang for ur buck / purpose and expectations its ok for now.
If it explodes during OCCT in the future i'll get something better i promise hehe. ^_^
