NeverBackDown
AMD Enthusiast
295X2. Just sayin.![]()
That's only 4GB though and he said he would rather have 8GB
That's only 4GB though and he said he would rather have 8GB![]()
same amount of vram shared between the two chips.
8gb vs 8gb innit.
Two 8GB 290x are slightly faster, especially considering they can be overclocked very highly, unlike most 295x2s because power delivery (excluding the two custom ones).
Same number yes. Not shared no.. You know it's split between the two.
If its two cards, it is mirrored not 'split'. Meaning GPU 1 and 2 have the same data Technically x2 cards work in the same way for the most part too.
Mirrored would imply the fact they the data is identical and they are not.If its two cards, it is mirrored not 'split'. Meaning GPU 1 and 2 have the same data Technically x2 cards work in the same way for the most part too.
Two 8GB R9-290Xs in crossfire sounds good to me. I have enough case airflow to handle it.
You can argue with this all you want, I pretty much just summarized a PDF from Nvidia.
Both cards have the same data stored on their ram. Thats the MIRRORED bit. all the data is not stored on one card.
Which is what?... case, fans, fan size & fan setup?![]()
Careful, He never backs down...... ^_^
