amd fx60 asus a8n 32 sli testing
name='unreal' said:
whats the water setup out of interest?
its a thermochill 120.3 pa rad. using 3x 120mm akasa super quiet fans.
swiftech storm block and dangerden double bay res. and a dangerden 655 pump m8. ;)
Is the ASUS board still limited to 1.58v mate?
What ram are you using?
If you could post PICS of your BIOS showing RAM and voltage settings it's be great DAZ mate.
Also your sig needs updating :)
Mav
I think the SLI32 has an option to use higher vcore, although I think it may still be limited when using dual core. Interestingly, that's a fairly high idle temp there Daz - I just built a FX57 120.3 setup for a customer and it was running at 3ghz @ 27 degrees idle but dual cores are reputed to run hot when you start overclocking. Nice clocks though mate.
