Amd 64 3000 754 Ram limit help
kawasakiguy37
I recently installed another 512 stick of pc 3200 corsair VS, but I couldnt remember if my chips memory controller cant handle 2.5 CAS with 1.5 gigs total of ram, or if it was it can only clock to 333 mhz fsb, or if its both. To be safe i set CAS to 3 and FSB to 333.
Help? Im hoping I can set CAS back to 2.5 or the mem back to 400
I cant find in the bios where I can set it to 2t?
Right now im running timings of 3-4-3-7 and DDR 333, lots of crashing on anything intensive.
On my DFI its CPC to disabled...but I dunno apart from that
Thats pretty crap mate...maybe stick with the 1024 and sell the other stick? :)
like kemp said..
cpc enabled = 1T
cpc disabled = 2T
hopefully you can set it with your board though.
After bit of extensive research, I found out that I cant ch ange the command rate with my processor. Clawhammer core does not support it, so now i have an extra stick of memory just lying around...migh tjust RMA it.
