Amazing how cheap it is to build a fast computer
|3ourne
You get that combo , BSEL1 mod your E4300 , you have a 2.4ghz fast computer with a decent onboard video. If you speed another 150 you get a really good video card too. So its a really good config for a gaming machine !!!! Like for example this 7900gs http://www.newegg.com/Product/Product.asp?Item=N82E16814130056 . Im sure there are better deals out there but DAMN !
Qty.Product DescriptionSavingsTotal Price1
AMS CF-7639BK Black Steel ATX Mid Tower Computer Case - Retail
Item #: N82E16811180044
Return Policy: Standard Return Policy
Add this item to your cart $38.99
PHILIPS 16X DVD�R DVD Burner With 5X DVD-RAM Write 2-Tone ATAPI/E-IDE Model SPD2410BD/17 - Retail
Item #: N82E16827248002
Add this item to your cart $29.991
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 533 (PC2 4200) Dual Channel Kit System Memory Model F2-4200PHU2-2GBNT - Retail
Item #: N82E16820231044
Add this item to your cart $129.99
1
SAMSUNG SpinPoint P Series HD160JJ 160GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822152020
Return Policy: Limited 30-Day Return Policy
Add this item to your cart $50.99
1
SpecResearch MKS-301(PS/2) Black PS/2 Standard 3-in-1 Multimedia combo Mouse Included - Retail
Item #: N82E16823157015
Add this item to your cart $9.99
1
COOLER MASTER Real Power RS-450-ACLX ATX12V 450W Power Supply - Retail
Item #: N82E16817171005
Add this item to your cart $59.99
1
-$5.00 Combo
$247.99
$242.99Grand Total:$562.93
Nice setup man. i dont really see the point in modding the e4300 as you can just stick the fsb up inthe bios though?
the point is the change the stock strap on the nb from 800 mhz fsb to 1066 mhz fsb to loosen the internal timings. This in turn helps you to go higher in terms of your overclock ( theoretically ). This in turn will let you run sync with high speed memory. Not to mention a HIGH stock speed , from 1.8 ghz to 2.4 ghz. Which makes it a fast computer right off the bat.
