Alternative to NZXT Sleeved LED Lighting Kit
andrevautour
Hey everyone,
I'm looking for LED lighting that is the same layout as the NZXT sleeved kit, so a 200mm cable with LEDs spaced out along it the same way (Vs the bitfenix alchemy style with the leds close together in a short strip).
I have had trouble with the 200mm white kit I have now flickering, and I've heard others report the same problem, so I'm looking for another brand that is the same sort of thing, but hopefully better quality.
Any suggestions?
Thanks!
I've heard great things about the phobia LEDs mate :)
Yes me too--the only thing I was weary about at first was the fact that those ones are build more like the bitfenix ones on a rubbery strip with the really bright LEDs close together, but the is mainly only a problem because you cant adjust them at all with the bitfenix stuff. I like the look of the IR controller with the phobia stuff, so that may end up working perfect. Esp since phobia has 'warm white' which is what I prefer over the cold blueish white.
