Alphacool Monsta 240 or 2 x 240 slims
MDB2012
Hi everyone,
A quick question if I may, I am planning to water cool my Cosmos 2. - my first try at water cooling except for a H100 which does not count !!!
Regarding the location for the 240 rads in the bottom of the case I see from TTL video (thanks Tom it is your video that finally convinced me to buy the Cosmos which is an epic case) that 2 240 rads can fit, now do I go for 2 rads or a Monsta 240 instead, and what would be the pro and cons of either.
Just to Note I plan to put a 360 in the roof as well - basically follow Tom's video as a guide!!!!
Any thoughts would be gratefully received
From the review it appears like two 60mm rads will fit but not two of the monsta rads. I'd personally go with the UT45 down there just to be on the safe side regarding fan, cable and fitting room and shove as thick a rad as possible in the roof.
Tbh if the slim radiators you were going to use are 30mm thick and it is a choice between the two of them or a single monsta, the monsta wins hands down.
Two 60mm rads would have a greater cooling potential than a single monsta rad assuming both are the same width
Thanks guys two 60mm rads it is then.
...Obvious question now... what rads and fan would you all recommend????...
