Naminator87
I've recently installed a Alphacool Eisbaer 360mm AIO, the temps are astonishingly good and I want to expand on the Eisbaer system, I've never done a custom Loop before, and just need some advice that's constructive and helpful.
The problem is I wanted to put a prefilled Eiswolf GPU Cooler on my Asus ROG Strix 1080 graphics card, but for some unknown reason they don't do one for this very popular card, I was hoping to utilizes the quick connect system of the Eisbaer AIO Hoses.
So once I have installed the extra rad as I have a z270 Maximus IX formula Mobo with a VRM block preinstalled so this will be added in to the loop also along with the GPU Block. So I ask what is the best way to fill this loop because it don't use a standard res and pump? Should I use the fill port on the block? Or should I install a fill port fitting on my 360mm rad? All my fitting are G1/4 on the Eisbaer and my VRM block, what hosing should I use as in size? is it still G1/4?
And I want to use UV Red in the loop any recommendations?
Thanks Guys
Thanks Guys
