Alleged GTX 1180 specifications leak
It looks like it to me. Not only is it a die shrink but it's also a much bigger die than the 1080.
It does have 50% more cuda cores then a 1080 so it would have required much more then a 2nm lithography shrink to get it smaller then the 14nm 1080 die. If it was a 7nm product then it probably would be a smaller die but the fabs are having issues with getting 7nm out the door.
1180Ti
Can't wait for 1180Ti leaks and specs, I'm hoping to grab two of them on release to replace my 980Tis
My excitement for GPUs is pretty low these days.
If we had more than just Metro I would be a smidgen excited. But given it will be every bit as good without RT then I am just all like "meh".
Ed. Check the dates of posts, dumbass (me). Stop necro bumping mate. Start a new thread.
Lol dude, the ”1180” hasn’t even been announced and you’re already on the next one after, ”1180 Ti”? :huh:...
I am sorted for now as with the 1080ti I am ok gaming at 3440 x 1440 or 2k 144hz with Gsync.
I will probably skipp this generation OR pick up a 1180ti as the 1180 seems too little jump for me.
A new GPU needs to run 4k at 144hz OR 3440 x 1440 @144hz for me to make a change. Untill then there are no games that makes me want to replace the 1080ti.
What I DO want though is a possible 1160 ITX card for a secondary pc with the 8400.
