Hi everyone, I would please like some help with this following mater. I have a very decent hardware and should be able to run AION somoothly, seeing the game's recomended settings (I have way better stuff than needed -- check my configuration and the end of the post please). The thing is, when runing with everything maxed out (4xAA, 1680x1050) I, sometimes (pretty frequent) experience FPS ratings even lower than 30FPS! And more, it doesn't matter if the AA is on 0x or 8x (yeah I AM "applying" the settings) or even if I tweak other graphic efects, even vSync, the FPS diference is, at best, 5 on avarage from the ALL MAXED to the ALL LOWERED. Another interesting fact is that when I ask the game to set the "recomended" settings for my rig with the auto-scan function it maxes out everything and put the resolution on the max possible, meaning the game was made for and knows that it should run fully maxed with my settings. So, thing is I run Crysis perfectly maxed (except from shadders, which is on medium) with 2xAA, 1680x1050 at an avarage 55FPS (no kidding) and run other demanding games maxed out, like Farcry2, DawnOfWar2, UnrealTournament3 etc. The only games I got problems with is AION and AgeOfConan. So, on the AION mater, please (check of my hardware) and tell me, is there any tweek or anything, like a driver (nVidia) that works better with AION (no, the LAST ones -RE NOT always -and for most of games this is sadly true- exacly the BETTER ones to run an especifc game with max FPSs possible), anything. Some people even told me that I should take my soundcard (Razer Barracuda AC-1) off and test the game's FPS, I fail to see why and how could this improve my FPS rating that much, since it (at least should) increases it (on theory) by taking work of the Motherboard, so I didn't tryed that (yet, if anyone convinces me with how it could work, I might give a try). So, again, anything (BIOS tweeks, drivers, etc.) that can help me, I would be VERY GLAD! Just be ware the I ALREADY tried all the basic stuff, like cleaning and reisntaling AION (compleatly) and nVidia ForceWare and nForce drivers trough Windows safe-mode, using driver sweper toll and re-downloading everything. And, NO, none of theese "solutions" have worked. Sorry for the long post! And thanks for reading.
Computer settings:
_Microsoft Windows Vista x64bits.
_Intel QX6800 2.9GHz OC'd to 3.5GHz. (temps. go to 74C. at peak with full load, thanks to Noctua's NH-U12P Heatsink with 2xNoctua 120mm coolers)
_EVGA nVidia nForce 780i. (A1 Version, with last BIOS -- P80)
_4x2GB DDR2 800Mhz Patriot Viper RAM. (5-5-5-15 timing, non-OC'd)
_PNY nVidia geForce GTX295 VGA 829MBx2. (multi-GPU/SLI on, Physx on, non-OC'd, last 190.62 WHQL drivers)
_Razer Barracuda AC-1 Gaming Sound Card 24bit and 96KHz interface. (Last 2.23 Vista non-WHQL drivers -- WHQL unaviable from Razer)
_1000W Akasa Power Max 80+ and SLI certified Power Supply Unit. (1100w at low temps. and peak load)
_2x500GB Samsung Spinpoint 7200RMP HDs with 8MB of cache each. (Never crashed, never had any problem)
Computer settings:
