Basically I'll be installing a new waterblock on the cpu. Got an Apogee XT on its way and was wondering how you guys would recommend taking it apart and reinstalling and leak testing it all. This time there could be residual water in the look so I'm not too sure that installing the block dry on the board and then plugging the tubing on will be safe. Maybe I should guesstimate the lengths, as its only a cpu loop cooling system, and leak test it in an empty case and then install the motherboard. What do you think?
Thank you.
Thank you.
