VforVengence
Hello gentlemen,
I need some advice on the above. First I will list my current system specs and then explain which components I wish to upgrade.
Current system:
OS: Windows 7 Ult 64 Bit
CPU: i7 920 @ 2.5Ghz
GPU: GeForce GTX 680 2GB
RAM: 6GB DDR3
PSU: 1000W
See photo:
These are the bits I have found so far. I need opinions on these.
Processor: i7 4770K
http://www.ebuyer.com/467641-cpu-core-i7-4770k-3-50ghz-lga1150-box-bx80646i74770k
RAM: (Not fully decided yet, but Corsair 16GB 1866MHz)
http://www.ebuyer.com/370057-corsair-16gb-ddr3-1866mhz-vengeance-memory-cmz16gx3m2a1866c10
Motherboard: Asus Sabertooth Z77
http://www.ebuyer.com/363671-asus-s...-channel-audio-atx-motherboard-sabertooth-z77
If you have any better ideas or the processor for example I have a choice between i7 3770k or 4770k. Ram - dont't really need more than 16GB as I'll mainly be playing Battlefield 4.
All opinions welcome!
Current system:
RAM: 6GB DDR3
PSU: 1000W
See photo:
Processor: i7 4770K
