Adding a 3rd colour ?
paulstung
I'm nearly to the end of my build, and am starting to think that it needs a 3rd colour to lift it a little, my plan was to go for black and white, with the odd grey cable thrown in the mix, with white fittings and black X1 coolant, but I'm starting to think it needs more.
My plan is to add it in the form of a 3rd cable colour and the fluid, but what colour ? I'm leaning towards either a nice green, or a light blue.What you can't see in my log is that I'm using white Bitspower fittings.
Si I'm going to leave it your hands, what do you think guys ?
Since posting mate, I'm sat back looking and getting the tube runs sorted in my head, I'm starting to think that, I'm even thinking about leaving gray out too.
For the coolant, I've been reading up about the Aurora 2, and it being more long term, and it has me thinking about getting the silver for a base, and adding the black X1, it will still basically be black fluid, but with a twist, I'm thinking that it will give it the lift it needs, if the silver comes through too much, I can go about adding the the silver/grey 3rd cable colour then.
