BigDaddyKong
Active member
I was test fitting some compression fittings in my new XSPC dual bay res last night. The outlet went in fine, but when I tried the inlet, it hit a rough spot about half way in, and I noticed some acrylic shavings in the res. It's not cross threaded, the washer is compacted evenly all the way around. It felt like the thread cut was not perfect all the way down. Once I got pas the rough spot in the threads, it screwed in as normal.
Is this normal to get a burred thread in acrylic res, and the need to make sure they are flushed really good before using them?
