Abit Sub Zero Overclocking Event
Philly_boy
This event was sponsored by Abit, Intel and Kingston. There are tons of pics in the links.
Links:
http://www.abit-usa.com/news/2006/20061219.php
http://www.driverheaven.net/articles/abitoverclock/
http://www.theinquirer.net/default.aspx?article=36526
So it is no surprise that these two companies held a private overclocking event on Friday December 15, 2006 to push the Kentsfield and the AW9D-Max to the extreme with the help of some of the biggest names in overclocking. So what happens when you get a retail Kentsfield, an AW9-D Max (modded hipro5 from Xtreme Systems style), a three stage cascade system, and a big container of ln2 (liquid Nitrogen) in a room alone with Charles “Fugger” and Don “Philly-boy” from Xtremesystems? Driver Heaven has the answer.
The Event
Right from the beginning things weren’t going as planned. Abit had sent a board directly to hipro5 to be modded and this was the board to be overclocked at the event. Unfortunately hipro5’s voltage mod had unknowingly been broken off during shipping back to Abit (and had to be re-added to get more voltage, and failed at a point later). And the day before the event, another mod touched the Zalman heatsink during the initial testing at Abit and the board was fried. So a copy cat modded board was made for Charles and Philly-boy. The nitrogen was also nowhere to be seen, so we started off with the phase change solution.
From there Charles and Philly set up Charles’s personal three stage cascade and finish building the system. The initial overclocking begins and all goes as planned until the circuit blows a few times. They get up and running again and Charles starts pushing, however the Kentsfield hits a wall very quickly. The chip is running about 120 below zero and it’s running too hot, where is that Nitrogen!?
It’s now past 10 am and the nitrogen finally arrives in a tank bigger than me. We disassemble and move the cascade setup to make room for the real fun the cascade. Now in order to get the nitrogen into a liquid state, Charles and Philly-boy have to release the pressure inside the tank because it’s gassier than an all you can eat bean restaurant. When the pressure is right, Charles rigs a direct feed nitrogen cooling solution and the party starts.
So at the end of an extreme overclocking day, what was killed and what was accomplished? A 1000 watt PSU was killed, Abit’s servers went down a few times, and we were worried that the AW9D was going to fry because of the condensation but it survived and prevailed.
Accomplishments were a 10.562 Super Pi which isn’t a record breaker, but getting the Kentsfield running at 5.010ghz with all four cores on normal voltage is a new world record. If the voltage mod had survived, we are all sure the Kentsfield could have pushed so much more. And while the overclocking achievements may be considered somewhat limited, there were some other great triumphs. Intel and Abit showed their commitment to the overclockers and their culture. Xtreme Systems and Driver Heaven proved their desire to be at the cutting edge of the overclocking scene. And Abit learned the post code for “Too cold to boot.”
In closing, we would like to thank Charles and Don for their hard work during the event as well as Abit and Intel for recognizing Driver Heaven as a leader in the enthusiast world.
name='v a d e R`' said:
Omgg! Philly-boy! I know him :eek:
Congrats mannn! :D
How do we know each other? PM me. . .
name='Kempez™' said:
Grats Philly-Boy. we had a news release from abit about this! Nice one mate, keep clocking :D
Yes, it *was* fun playing with FUGGER'S three stage cascade and the LN2.
name='Toxcity' said:
OmGG Nice work Philly!
You are the Kingpin of OC3D! :worship:
Not quite K|ngp|n yet. . .but having some fun learning about serious sub zero cooling and how to wreak the last nth mhz out of a CPU. . .
I think he means more like you're on the news and he's saying, "OMG I've talked to that guy on a forum!" maybe not though
Philly and I may have a bit of a get together to clock the living shat out of some stuff. Probably in Febuary and I'll bring a single stage or two and the cascade (should be done long by then)
Not just yet Kemp, but I'm sure if we've got the cooling we're wreck something. I may use it as an excuse to get a new video card if I bring the x850xt for sacrifice.
