Hi there
I'm back home from uni now, here at home we've got a standard wireless network going on for internet etc.. I can to install my old wireless pci card (MSI something or other) only to find that the drivers do not work. I searched the internet only to find that it is simply a very old card and the newest drivers are those that support xp 64. I tried to download and install those but had no luck there.
So i set about getting a new card.. I ended up with:
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=530773
Abit AirPace.. simply because it was cheap enough and I could find sostware on the internet for 64 bit Vista.
I've tried to install and setup the card but to no avail
So far I have:
* Fitted the card and installed 64 bit software ( They install fine but I get a message saying that it cannot detect the card)
* Removed software, reinstalled, refitted (Again same results)
* Tried installing the software with no card fitted (This will not install the drivers)
So I know that the imputer detects the card and if I go to the device manager it shows as Ethernet Controller. When I have installed the software nothing changes and device manager still says it can't find it!
If anyone knows any steps that I can take to make this damned thing work then I will be incredibly grateful
I'm itching to play TF2!
Right now I'm off to try a fresh install of vista on a spare HDD, otherwise it might mean back to XP for a while
Thanks for taking the time to read this epic!
Cheers guys
Cheers guys
