Hi guys,
I've been using my system for a while now and all was well until i got a raptor 150 from Big Phil. I put it in and it failed to boot after installing windows and smart told me to replace it, so off for rma it went. While it was away it got upgraded (in their eyes) to the raptor 150 x (the one with a window). I couldn't be bothered to complain so i just threw it in and the following happened.....
Formatted - Fine
Copied Files - Fine
Reboot
BSOD - Motherboard is not ACPI compatible (WTF!!!)
So i logged on to the forums over at asus and it would appear there are lots of people who have this problem. I tried every single suggestion....
-Enable paralell port
-Turn APN off
-Change bios
All to no avail! I have tried every bios there is and nothing works **BUT** if i unplug the raptor and boot off my samsung spinpoint 250gb all is fine, and i didn't change anything in the bios settings either.
Oh and the raptor is 100% healthy before someone says it's the hard drive because it is currently installed on my wifes machine!
HELP HELP HELP HELP!
Formatted - Fine
Copied Files - Fine
Reboot
-Turn APN off
-Change bios
