Hey, new forum user, long time lurker here. I am currently in the process of setting up my own custom loop. I have done it before but I've been out of the game for a few years now. My question is; What rad should I put into my loop and I also need suggestions for a good drain port, fan controller and LED lights for the case. This is my specs, price for parts is not an issue:
- Corsair Obsidian 900D (Know how to work a Dremel and I'm willing to do so)
- Asus Maximus V Formula (Will watercool the Thermo Fusion)
- i7 3770K
- 2*8GB dominator Platinum
- Gigabyte Geforce GTX Titan 6GB
- Corsair AX860i with red individually sleeved cables
- Samsung 830 256GB
- WD Black 1TB
I am currently using AF120+AF140 Quiet for case fans and SP120 Quiet PWMs for my H100i which is installed now. I am happy with these and plan to use SP120's for the rad in push pull.
The watercooling gear I have aquired so far:
- EK Supremacy Acetal
- EK-FC Titan XXL Edition including backplate
- EK-D5 X-RES 100 CSQ - Acetal
- Laing D5 Vario (12V DC Pump motor only)
- EK-RES X3 - TUBE 250 (204mm)
- 12* EK-CSQ Fitting 12/16mm G1/4 - Black
- EKoolant Blood Red *3
-4* 5/8 hose clamps
- Bitspower FillPort, M20 + 1/4"BSP, Matt Black
- Bitspower Blind 1/4"BSP
- Masterkleer 11,1mm/15,9mm Clear tubing 3.3M
That's basically my gear. I need a radiator that's quiet, I hate noise. I would also like a fan controller and I wonder if Corsair's fan controllers are compatible with Corsair Link software? I also need to light my case up in red light but I have no idea what to get there either. I'm also unsure what drainport will fit my system with so many of them available. I live in Norway so links to norwegian shops would be appreciated but I can of course order from Europe as well. Thanks for reading
- i7 3770K
- Samsung 830 256GB
- WD Black 1TB
-4* 5/8 hose clamps
