I have an ASUS A8N5X 939 Mobo
http://www.asus.com/products4.aspx?l1=3&l2=15&l3=207&model=596&modelmenu=2
And I have 2 kits of this so it will be 4x512MB which is hard on the mem controller
http://www.newegg.com/Product/Product.asp?Item=N82E16820231012
I have a revision SH-E6 4000+
I know I will have to run in 2T
but will I be able to run the RAM @ like 230 MHz (460 MHz DDR) I know it can't go past ddr-333 though and I have to oc the CPU to raise the RAM speed.
The cpu is @ 3000 MHz. So what multi and fsb to use?
will the ram oc be enough to cancel out having to run in 2T as opposed to 1T?
What voltage would you expect the ram to need?
Of course it will be dual channel.
Thanks
Thanks
