900D red&black rig w/ custom loop
Really nice looking build.
I am still debating whether to buy one of these cases today or not.
I love this case. They put so much thought into it. The build quality is exemplary. It's soo sleek and elegant. If you can get a good deal for it I wouldn't hesitate. It's also 200€ less than the TJ11 yet it beats it in every aspect. The only thing I can see beating this are the Caselabs cases and you're talking 500€ and upwards for those. A heavily modded TJ07, maybe. But not really.
She is a beauty! Very nice build mate.
Tempts me to put a custom loop in mine, I am so close to the edge it's unreal :p
Great looking rig.
I nearly went with caselabs but it cost the earth to ship to blighty,i wish someone could open a distribution here it would be a gold mine.
Great looking rig.
thanks. i prefer the looks of the 900d compared to the caselabs stuff, but none the less a distributor in europe would be nice
did some dustfilter cleaning today, also took a couple new pics
OP is now updated
also, cpu now running at 4.5 @ 1.275v with RAM still at 2133
OP is now updated
Still looking gorgeous! ^_^
Love that deep red coolant :p
I've had to lower my ram from 2133MHz to 2000MHz at 4.6GHz and I think I have to run it at 1600MHz for 4.8GHz, I'm not a good overclocker I guess. People can get 4.6/4.8GHz and run 2400MHz :/
might just be a bad chip. mine won't do 4.6
What are your temps like with the 3 rads?
I'm correct in seeing 1 loop only yes?
Wasn't sure if you were using a drive bay reservoir like many for the second loop.
Previously I had a rad up top and 1 in the bottom like you have but changed that for both rads hidden away in the bottom. I noticed that after 3hours in BF4 my tempts were 20degrees lower. Although removing the metal cover on the lower flaps did help alot as it has a nice push pull effect with both rads sucking air from one side to the other now.
Yeah only one loop. CPU usually around 60-65 - might have put a bit too much thermal paste on that -, GPUs 37-42 at about 22C ambiet
