sdamaged99
Good afternoon guys
Well i've been watching Tom's videos for ages now so thought i would start using the forums to see what the community is like, as i've used ocuk and guru3d for years now.
I was looking for some advice on the best install method for my kit into my new 900D case (bought after watching Tom's extensive review, twice!)
If i list my kit below, perhaps you can give some pointers on where stuff could go for the cleanest look
Intel 4960x
Asus Rampage Extreme IV
32GB Samsung Green
2 x mechanical drives
2 x SSD
EK 4.0 Pump (pretty ugly but a cracking pump)
Bitspower Z-Multi 400ml tube reservoir
360mm x 80mm Alphacool Monsta Rad
240mm EK Radiator
Radeon 295x2 with full XSPC Waterblock
Supreme HF CPU Waterblock
Cooler Master Silent Pro Gold 1000w PSU
Red bitfenix cable extensions all around
Scythe Gentle Typhoon 1850 x 5
Zalman 8 fan controller
think thats it!
I am moving from a switch 810 which is great but i didn't really have any room for the pump to go, it was sitting on the bottom 240mm radiator which just looked crap aesthetically as you could see it through the window, plus the cable management room on the back was terrible and i couldn't close the case without really squeezing it
I was going to ask if i should put the 240mm rad on the bottom, and also put the pump down there as well, that was it should be hidden when the bottom panel is closed? Also is that enough radiator or do you think i should have replaced the 240 for a 480?
Anyway, hello from the Isle of Man!!
Intel 4960x
32GB Samsung Green
2 x SSD
240mm EK Radiator
think thats it!
