dipzy
Active member
hey guys got a question for you. I got a 8pin (4+4pin) extenion cable for cpu power and i want to use it with the 8pin on a ax850 but the 4 of the holes the ax850 cable are different to those on the extension cable.
I tried connecting both cables together and they fit fine but concern is will be ok to use it?
