hi all,
some advice/help in the following,
have 8800gtx stripped down to fit EK full cover block and have purchased Coollaboratory liquid metal pad to use.
on opening the pack, i find the size of the pad is only 20mm square and the 8800 gtx die size is about 40mm square. it is recommended for nvidia and ati cards...but will the pad liquidify enough to cover the full gtx die size??
or better just to use mx-2 to be on the safe side?
