7950GT (256 or 512) or ???
AvengerUK
Hi all,
Im considering a 7950GT for my new build, either 256 or 512, proberbly 512 leadtek card if i can afford it!
Is this a good card? i.e. no "issues" with it? e.g. IQ good etc lol?
Cheers
if im not mistaken unless the 512 mb card is within a £10 difference of the 256 mb version, im not sure it would be worth it. You will only see a very minimal difference in performance between 512 and 256 unless certain applications require a bigger amount.
If its only a 10 buck difference then what does it matter? More bang for the buck. I have the XFX 7950GT Extreme(512mb) and its really an awesome card.
Don't forget they're in the UK, so it's more like $20, but still, that's pretty close
Thanks for the advice.
Looking at the Sparkle P795+ card (7950GT 512) or a Inno3d one. Anyone know about the sparkle one? it looks quite good (high factory OC, attractive price etc)
Thanks
What's your decision for choosing an nVidia card over an ATI one? Just wondering what you can get on the ATI side for the same price..?
Vista when a Service pack is released and things in general "work better" (or just work) with it!
Im not going ATI as my last computer had a X1800XT 512mb, and, it was less than stable. Not the card, but the ATI drivers. Seriously, why does anyone put up with them!!?!?
