FragTek
Well seeing as we don't have a thread pertaining to the new 7900's here it is
Let's take a look at what nVidia will be unveiling shortly shall we?
7900GTX Specs & Notes:
*32 Pixel Processors (g71 8 cores x 1 quad x 4ps = 32pipes)
*Core: 700mhz stock, up to 750mhz (I would assume from manufacturers such as BFG / XFX / Leadtek that overclock them slightly from the factory.)
*Memory: 900mhz GDDR3 1.1nanosec, 512mb
*Process Fab: 90nm
Also...
1.FP16 render target MSAA support: Improves quality in which HDR is processed
2.Hardware FP16 --> RGBA: new type of multi samp AA, whats known is that it will allow nvidia to use HDR and filters (ati has it implemented already)
3.Hardware FP16 texure compression: compression of textures over 16fp(AS?) since HDR+FSAA consumes alot of the available bandwidth.
7900GT Specs & Notes:
*24 Pixel Processors
*Core: 650mhz
*Memory: 1400mhz with 512mb
*Process: 90nm
It would displace the 7800GTX 512mb since they wont be produced any longer.
Also, they will release the 7600 series, although there isnt much more info available about it. It is known that Nv will retake the mid and low sector market around april.
That's all I have for now. Any of you blokes have anything else about the G71's?
*Process Fab: 90nm
Also...
*Core: 650mhz
*Process: 90nm
