SuB
The Webmaster
So I've changed my 580's over to 780's and the joyous rapture that is my frame-rates is lovely
I overclocked my 580's using EVGA Precision, added some mhz here and there, added a little voltage etc..all was fine n dandy.
The new 'offset' stuff and 'power target' is all a bit like whuuut ?!?!
I added some offset (100 or so), ran some benches WOWSERS the scores went up, great, added some more (up to 150), and got some driver crashes/hangs... bugger.. is 150 too high? tried 135, same issue..
I set the power target as high as it'l go (they're waterblocked so temps are not an issue at all) and it didn't seem to make an awful lot of difference, although the voltage looked like it increased a little.
Do I need to pump the volts using the voltage panel as well on these? I've never done the offset/boost clock style overclocking before lol
Forgive the n00by question I just haven't overclocked using these types of cards before. If I need to pump volts that's fine
just wanted to know.
TA Muchly
TA Muchly
