As above just got hold of a QX9650 and have fancied trying out WC for a while and figured to really get the best from the chip then WC is the way to go. Problem is budget! WC seems very expensive and tbh i have no bloody idea what i'm looking at. At the momment i'm running a pretty decent air cooler so would be looking for a decent improvemnet but i know this will come at a price. At the momment i am only thinking about the chip and then take it from there. I would rather try a pick some used bits from here and other places then new as then i would more than likley get higher spec gear.
Below is my setup, is the case suitable for a WC setup?
Silverstone TJ09
QX9650
4870X2 - Accelero Extreme cooler
P5Q Pro
4GB Patriot Viper 1066MHz
Tagan BZ800
Prolimatech Megahalems
Don't know how much difference watercooling the GPU would make as i already get superb temps with the cooler.
I have looked at kits but i presume they are really not much better than a decent air cooler?. So just looking to get the chip done first so any help appreciated as i have no idea what i'm looking at. Is there anything else i should think about doing or just the chip for starts?
Silverstone TJ09
QX9650
P5Q Pro
Tagan BZ800
