7600 gs gainward probs
limqareb
first thing i cant sli them cause of the
ing 2 slot cooler and it hits the XFI and 2nd thing they both have dvi , and when i put the converter to vga or whatever no signal is detected , i tried both cards doubt both blown and i tried using a kvm and on the current pc it worked fine but as soon as i change to other pc no input detected!!
could it be cause of the montior?
Since when did they start putting dual slot coolers on 7600GS's??
And your monitor may not like being switching from one frequency to another, what vid card are you running in the second computer? What kind of monitor as well?
ed off i cant even install windows on my new pc i sit here on a piece of antique work waiting for my XFX 8800GTX XXX to arrive cause no one helps
a friend of mine too has this prob but he didnt change the video card he just got new mobo , cpu and stuff but it is not detected by the monitor too, i checked the post codes and so on and everything is fine as if it was working but no input comes on the screen WTF??
Woww dude 6 posts in a row..take it easy..use the edit button.
Nobody can help if they don't know what the answer is.
If people did reply no doubt it'd be:
RMA or a new card.
RMA or a new card.
i have the new pc and i am damn eager to use it but how can it be new card just bought and i changed since i got 2 to put in sli and i tried both and none worked , resetted cmos and tried every single thing there is but i dont want to wait 2 weeks till the 8800 gtx comes to use the pc :@
Do you have an old card you can try using?
Try doing the ol' one stick o' ram trick.
nope no extra pci e card what do you mean by ol one stick ram trick?
edit : i have 2 7600 gs but
