6990 water cooling log
ya dont need a stove bro lol you got a 6990
hahahahahahahaa ok great log so far but dont forget the geek porn when ya undress da card
most defiantly
smore pics:
There is only 1.4" of room ro fit the RAD, and the RAD is 1.4" thick.
Had to remove the clamps that hold the fans in place in order to make more room. Thank god for double sided tape (HOLDING VERY WELL).
And yet another problem. The 8PIN mobo connector is in the way of the RAD area. Gunna have to figure this one out.
Just another pic.
ALL DONE!!
Some pics of the other parts that came in today. (this is a test loop)
Here is the shiny hotness. (test loop)
6990 pr0n
Some more pr0n
Close up pr0n
Had to put the RAD in the back. there was not enough room up top.
Block installed.
just another pic
So there you have it folks. Let me tell you, being a first time water cooling person THIS WAS A TONE OF WORK (or maybe i made it more than it was needed). Either way it was worth it. My GPU in idle stays around 42c and 45c with the pump 1/2 way and i am only using ONE fan. I will be adding more fans in the future but for now i am really worn out.
