6950 Crysis 2 - DirectX11 + High res texture pack
Best get a single beefy card. Not very familiar with SLI or Crossfire but i've heard there can be some issues.
I play the game on 1920x1080 with a 580, its a gigabyte oc'd version however, with the dx 11 upgrade packs it still runs really really well. Not sure on the FPS though, is there a console command to check it on this game or do i need something like fraps??
Just use Fraps, Afterburner, or even use the Adrenaline Crysis 2 Benchmark Tool. You should be getting around 50s average (actually are you running the hi-res textures too?), maybe a sub-30 from time to time
Yeah i am running both dx11 upgrade packs, i checked it out i am getting pretty consistent 50-60fps. I haven't seen it drop under 50 even on heavier load.
I have got it running a core clock of 930 however.
Not bad
I was just wondering because I have a 6850 which is just as powerful as a 460, I know what performance to expect in Crysis 2 with DX11 and high res textures now.
Pass the joint...
At last check a 6850 wasn't as fast as a 5850. Then when you consider that a 460 1gb is up there (pre overclock) with a 5850 then I think you have your sums wrong man.
Pass the joint...
The 5850 is not that much faster than a 6850 to be fair.
5850 vs 6850
http://www.anandtech...duct/295?vs=291
6850 vs 460
http://www.anandtech...duct/313?vs=291
Obviously with an overclock the 460 would be faster but if the 6850 was overclocked as well then they would be around the same.
