I`ve seen a load of Intel OC screenies, and reports of FSB not passing 225 or whatever. How does this relate to the RAM speed? is the FSB doubled for the RAM speed?
For 65nm, what are the normal upper limit of safe voltage under water and phase?
Does cooling the chipset properly help with the OC as the memory controller is on it? Because the RAM controller is off-chip, do dividers really hurt performance?
LOL...last one... how does the average CPU speed scale on air? Similar idea to how most Athlon64`s will do 2.8-ishh on air, regarless of start point, whats the equivalent for the intel at the mo? 220ish x multi as FSB is an issue?
Kenny
P.S... Any of the above info on Presler, Yonah and Conroe welcome, doesnt seem to posted much as its so simple
Kenny
