650d front rad sandwich ?
paulstung
So my problem is I have a very easily bored mind and with ocd, am constantly searching the web for ideas/mods i haven't seen done before.Whilst researching cases for a new build I've started looking at the 800d but i live in a small 1 bed flat with my desk in the corner of the living room,so I outed that option and looked at the 650d.
The size seems perfect,but I have a funny thing about,when water cooling most people mount the rad in the top,in the hottest part of the case,so to me it doesn't make sense front/bottom mounted makes more sense,obviously with enough exhaust fans to get rid of the warm stuff.
But in the 650d it has a front 200mm fan,so my idea is,after seeing some one(not sure if it was here) do a rad sandwich,could I implement that into the front with a pair of Phobya 200mm rads in push pull ?
I have no idea if it is even possible or even worth while,but my way of thinking is that cos with the rad being front mounted and the warm air is going into the case, and over the components the extra rad would help ?
Like I said this is purely a thought and by no means a work in progress I just wondered .I haven't really started researching water cooling yet and I admit i now jack sqwat about it.Research,research and more research before any attempt will be made.
