Go the 600T it's not as much of a hot box.
650D = 600T just a little taller, so unless your watercooling they are exactly the same
Ya i do notice the issue, but is it possible to fit in a 300mm radiator only at the top? In performance wise, can it cope? I also just posted another thread on this :-
http://forum.overclock3d.net/index.php?/topic/42233-radiator-size-advice/
Perhaps anyone can help? I'm a total newbie by the way in water cooling and this would be my first build and on a tight budget as well![]()
Hi, thank guys for the advice and oh wow, its ttl answering my question.. For now ill be using the 600T and just stick with air cooling for a while. Maybe overtime, I might be modding the case to fit WC as well. We'll see how my WC excitements hangs on. This is my first WC attempt though by the way. Many12 thanks for the advice![]()
so long as you don't want an optical drive
