Hi guys, back with yet more problems for you to ponder over. you've been a great help so far, so fingers crossed we can get this working too.
I've had the Asus P5N32-E 680i mobo for a while now, working perfectly with 2x 1Gb sticks of OCZ DDR6400 Platinum Rev2 RAM for a good few months now, the mobo did undervolt it, but not enough to stop it booting first time, and alowing me to up the volts to the recomended 2.1V.
I've reacently got a seconds pair of the exactly the same RAM, and after inserting both sticks my pc simply fails to boot (BSOD as it were!).
I checked my bios settings and everything is still set to 2.1V's, however after the BSOD everything is reset to default. its an easy fix back to my OC'd settings and the 2.1v for the ram, but annoying that i cant get a nice 4Gb system up and running.
my guess is there isn't enough V's getting to all the RAM, but i thought i'd ask here before i go ahead and chuck more Volts through the RAM and risk blowing it!
basicly am i on the right track with the more V's theory, and if so, what would you recomend i up the V's by untill i get the system running and stable, also whats a safe limit to push up too, so i dont end up frying everything.
I have an OCZ RAM cooler, but in order to instally it i need to take out my 8800GTS and its a lot of mucking around just to plug and unplug some ram, so for the time being thats not going to be used untill i get the system back up and running.
Thanks in advance for the help, and any more info needed just ask.
Regards
Kenzie
Regards
Kenzie
